03-20-2019 05:23 AM
Hi Sir ,
am Trying to run an executable on a remote pc from Teststand. looking around i found a possible/easiest solution is to use that RemoteEXEServer.exe (wich is provided by installing Teststand) & Call Executable Teststep.
I configured every thing similar to AllenP's description
Trying to put a password already throws an exception from HRESULT:0xFFFFBBA4 Error Code: -17500, Operation Failed.Source: NationalInstruments.Teststand.Interop.Api. see "exception_pwd.png" for details.
leaving di password field empty then running the teststep causes a Run-Time Error: -17502; System Level Exception. See second picture "run_time_error.png" for details.
03-25-2019 10:27 AM
Have you seen these articles surrounding your error codes?
Error -17500 Using The Property Loader From Caller Sequence: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DdMLSA0&l=en-GB
TestStand Error -17502 Using Automation Server: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019ToqSAE&l=en-GB
Michael
04-03-2019 02:16 AM
hi,
yess, these 2 articles were di first thing tried.
have you got it to run? remotely? because locally every thing is ok!
one problem appears just by typing a password (error -17500 ) and i dont think that i have any influence on that (maybe a bug?).
by the way am using Teststand 2017 SP1 32bit
04-03-2019
06:34 AM
- last edited on
11-04-2024
12:59 PM
by
Content Cleaner
Have a look over this.
Remote Execution in 32-bit TestStand and 64-bit TestStand: https://www.ni.com/docs/en-US/bundle/teststand/page/remote-execution-in-32-bit-teststand-and-64-b.ht...
It might be to do with the set up
04-11-2019 05:56 AM
Sorry u misunderstood, CallSequence on RemotePC has nothing to do with RemoteEXEServer.exe and Call Executable:
CALL Executable Remote Conf
RemoteEXEServer
SquenceCALL
04-12-2019 02:47 AM - edited 04-12-2019 02:47 AM
did someone ever seen it working?
