NI TestStand
Remove Login
Hello-
How to remove the Login Dialog Box of the my TestStand application while I start up the application?
many thanks-
Message 1 of 8
(37,348 Views)
This is a very interesting question.  Who would you like to login to TestStand?  Or would you rather just not worry about permissions?
If it is the latter question then go to Configure>>Station Options and on the User Management tab uncheck Check User Privileges and uncheck Login on Start.
Also, you should understand front end callbacks: https://www.ni.com/docs/en-US/bundle/teststand/page/modifying-front-end-callbacks.html
The dialog is coming from the front end callback.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 8
(37,332 Views)
Many thanks for your helping.
I am run the .seq file under Labview application. when I start up the labview, the application will popup the Login? I want to remove it, and I are looking for this, please help.
Message 3 of 8
(37,328 Views)
Do you have sequence editor on the machine that you are launching the LabVIEW User Interface from?
As said earlier, if you do not care about permissions at all, go to Configure>>Station Options>> User Manager and you can uncheck the "Require User Login," and uncheck "Check Privileges." See the following Help topic - https://www.ni.com/docs/en-US/bundle/teststand/page/managing-users.html
Otherwise, if you do not have the sequence editor on the machine, you can programmatically modify the LabVIEW operator interface to modify these station settings before the application manager is launched or modify the front end callbacks as mentioned earlier.
Message 4 of 8
(37,298 Views)
Greetings-
I have no the sequence editor on the machine, and I am using LabVIEW User Interface to run my test sequence. when I launch "TestStand Operator Interface", the Login window come up, I want cancel the window and don't appear when launch the TestStand Operator Interface.
Message 5 of 8
(37,289 Views)
Did you read the previous two replies? They are workable.
Message 6 of 8
(37,280 Views)
hello,
Many thanks for your time, 🙂
yes, I have got the information and tried to do, but I have no TestStand Sditor.
Have a good day!
Message 7 of 8
(37,276 Views)
This feels related an may have your solution: https://forums.ni.com/t5/NI-TestStand/Including-TestExec-ini-in-Deployment/td-p/356919
jigg
CTA, CLA
testeract.com
Message 8 of 8
(37,259 Views)
