NI TestStand
Using XNET database in teststand with selectable signal list
I have problems using the XNET database in teststand. I want a drop down menu of all frames(or signals) of a XNET database in teststand. Is this possible? I tried a VI that has a frame list and a signal list as input. When I click in the inputs using Labview, I can select my database and then the frame or signal. I saved the Labview-project and reloaded the VI in teststand. With teststand, the frame and signal lists are empty. The connection to the XNET database might be lost. I tried the Open Database function in Teststand but this does not load the XNET databases (udl file needed).
What can I do?
Greets
ManuKlause
LabVIEW 2018
Veristand 2018
Teststand 2017
(3,015 Views)
Hi ManuKlause,
I've got a product doing exactly this (step types collection + edit steps to read/write signals on a CAN bus based on a XNET DB).
You can contact me directly if you'd like to now more about it.
However the trick here is that we also had a hard time to make it work.
We ended up displaying rings which are populated thanks to XNET DB queries results...
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,986 Views)
