NI TestStand
Rename step using parameter of caller subsequence
I have a call to subsequence called "ena". The sequence "ena" accepts parameter nemed "one" of type Number. I call this subsequence with variable (Locals.pet which holds value 5) and I want to rename the step in report as:
Step.Name = "Calling subsequence using parameter one's value " + Step.TS.SData.ActualArgs.one.Expr.
This would result in step name reported as "Calling subsequence using parameter one's value Locals.pet". How to modify report to get step named as "Calling subsequence using parameter one's value 5"?
(1,050 Views)
Accepted by topic author VArh
Step.TS.SData.ActualArgs.one.Expr is an expression. To achieve what you want to do, you need to evaluate the expression.
https://www.ni.com/docs/de-DE/bundle/teststand/page/tsfundamentals/infotopics/evaluate.html
This should do the job
(1,038 Views)
Great, that works - i.e.:
Step.Name = "Calling subsequence using parameter one's value " + Str(Evaluate(Step.TS.SData.ActualArgs.one.Expr)
evaluates in report as:
Sub question:
If passed passed variable is enum, how could I evaluate enum name and value in step name?
i.e.:
would evaluate (when variable is enum) as:
"Calling subsequence using parameter one's value controlling"
I would also like to display value of it, like:
"Calling subsequence using parameter one's value 5 (controlling)"
Is this also possible?
(1,002 Views)
Good question, I had to look this up myself.  I was surprised to find the answer to be intriguingly simple....
Just use the Str() function to convert the enum variable value into a string
(997 Views)
