NI TestStand
Report File Substeps only listed when more than 2 entries are present
Hi All,
a short question regarding report file generation. Our report file has the problem that the substep report texts are only printed when the substep has more than 2 entries inside. Once the third entry (even it is some dummy entry, but it must write something to the report file) is present the sub report texts can be found inside the report.
Michael
(2,865 Views)
Can you post an small example showing your problem?
Regards
Ray Farmer
Regards
Ray Farmer
(2,863 Views)
