NI TestStand
Report Page is blank.
When I initially began utilizing TS, I would receive reports on the report page; however, after a while, the page turned blank. Can you please assist me with this issue? I think I have all the configurations set correctly too.
(1,015 Views)
There's two main possibilities:
1.) The settings for the  report being displayed  are somewhat messed up
You can check, if Report_2 shows a result if being displayed. Or just create a new report to be generated and see if it works
2.) you have disables the report generation on (Main)Sequence Level
(974 Views)
How do I get to the mainsequence level properties?
(959 Views)
Option 1.)
Having your MainSequence selected in the SequencePane and then use the Edit Menu
2.) Rightclick on the MainSequence in the SequencePane
(946 Views)
