TestStand 2012 SP1, have setup 2 Result Processing.  The issue is the informaton needed for the Report Filename and Directory are not known until later in the flow (after entering Part Number and Serial Number).  TestStand doesn't generate the correct filename, due to the data not being available, and because the data isn't available the Generate By Expression isn't functioning.
I have gotten the Generate By Expression working, but only by adding it to the ReportGenerator.seq.  To continue with this approach, how to I determine which report is being generated so I can have 2 file names/locations?
