NI TestStand
Retrieve comment and version properties form a sequencefile
In our user interface (LW-CVI60) we want to retrieve the comment and version property of a currently loaded sequencefile.
Where can I find a sample code to solve this problem ?
Is it possible without the use of lookup strings ?
Message 1 of 8
(3,892 Views)
Hi SoftToon,
You will need to use the following to find the Comment
oleErrChkReportErrInfo(TS_SeqFileAsPropertyObject (seqFileH, &errorInfo, &propObjH));
oleErrChkReportErrInfo(TS_PropertyObjectFileGetProperty (propObjH, &errorInfo, TS_PropertyComment,
CAVT_CSTRING, &seqFileComment));
Likewise to obtain the Version use TS_PropertyTypeVersion instead of TS_PropertyComment. This property is also a string.
Depending where you call this functions seqFileH maybe available. If not you can obtain this reference by calling
oleErrChkReportErrInfo(TS_SeqContextGetProperty (seqContextH, &errorInfo, TS_SeqContextSequenceFile, CAVT_OBJHANDLE, &tmpSeqFileH));
Dont forget to free any tmp references.
Hope this helps
Regards
Ray Farmer
Message 2 of 8
(3,892 Views)
Hi Ray,
I have treid your sample code, but it does not work.
For the comment property I have changed your sample into:
OleErrChk(TS_SeqFileAsPropertyObject (gCurrentSequenceFile, &errorInfo,&CurSeqFilePropObj));
OleErrChk(TS_PropertyObjectFileGetProperty (CurSeqFilePropObj, &errorInfo,TS_PropertyObjectFileData,CAVT_OBJHANDLE, &PropFileObjHandle));
OleErrChk(TS_PropertyGetProperty (PropFileObjHandle, &errorInfo, TS_PropertyComment,CAVT_CSTRING, &getDescription));
This because TS_PropertyComments is not availeble in TS_PropertyObjectFileGetProperty
So for the comment propery, my problem is solved but for the version property I have still a problem because when I change the TS_PropertyComment into TS_PropertyTypeVersion, I get an error "operation
is valid only on types".
Do you have any suggestions ??
Message 3 of 8
(3,892 Views)
HI,
Sorry about that what I should have put was
oleErrChkReportErrInfo(TS_PropertyGetProperty (propObjH, &errorInfo, TS_PropertyTypeVersion,
CAVT_CSTRING, &typeVersion));
and likewise the for the comment.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 8
(3,892 Views)
Hello Ray
Thank you for the quick respons, but as I mentioned in my last reaction, TS_PropertyComment works fine but, TS_PropertyTypeVersion causes an error with the message "operation is valid only on types".
Thus replacing TS_Propertycomment with TS_PropertyTypeVersion does not work...............
Regards
SoftToon
Message 5 of 8
(3,892 Views)
Yeah I realised that when I spotted my error in my initial response but it should work with TS_PropertyGetProperty instead of TS_PropertyObjectFileGetProperty (which I initially quoted) as TypeVersion is a property of PropertyObject ( see TestStand Programmers Reference manual ).
Hope this clears any misunderstanding.
Ray
Regards
Ray Farmer
Message 6 of 8
(3,892 Views)
Hello SoftToon -
I believe the KnowledgeBase entry for,How Do I Access a TestStand Sequence File's Comment Subproperty Programmatically?, will assist you with your question about accessing the comments. This tactic leverages a generic API method, so it will work so long as you have some reference to a sequence file that you can treat as a property object. See the attached code for details.
Concerning version strings for a file, in TestStand 2.0.x. there is no method available to quickly expose the version of a file. In this case you will need to use a lookup string. First make sure that you can see TestStand hidden properties (using menus: Configure>>S
tation Options and examine the checkboxes available on the Preferences tab). Now you will have access to the lookup string:
RunState.SequenceFile.Data.Version
You can retrieve this string value any time after loading a sequence file into memory.
Regards-
Elaine R.
http://www.ni.com/support
Message 7 of 8
(3,892 Views)
Ok, taking Elaine's comments onboard, this snippet works a treat.
oleErrChkReportErrInfo(TS_PropertyGetValString (propObjH, &errorInfo, "Data.Version",
CAVT_CSTRING, &version));
enjoy.
Ray
Regards
Ray Farmer
Message 8 of 8
(3,892 Views)
