Retrieving the COM class factory for component with CLSID {B2794EF6-C0B6-11D0-939C-0020AF68E893} failed due to the following error: 80040154 Class not
Hello all,
i am trying to interact from c# wpf with the TestStand engine.
when i run the line:
m_Engine = new Engine();// lets get an new Engine Object
i get this error:
Retrieving the COM class factory for component with CLSID {B2794EF6-C0B6-11D0-939C-0020AF68E893} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
i have TestStand 2019 32bit on Windows7 64bit.
in the registry i found this guid as related to  TestStand2019\bin\teapi.dll
i tried to register teapi.dll with regsvr32 and it gives a "registration succeeded" message - but even after that, i get the same "class not registered" error
i tried to register TestStand 2019\API\DotNET\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.API.dll but getting a message that it does not contain dllregister (meaning that its not a com object).
i did succeed registering it with regasm (that registers c#  and interop dlls) but even after that, i still get the "class not registered" exception
so am i trying to register the wrong thing?
please advise
Thanks in advance
Lior Meister
(17,782 Views)
Is your application's platform set to 32-bit (x86) ? If you don't install 64-bit TestStand, then you probably need to do that.
(17,756 Views)
Thank you for ypur answer.
Yes. My c# (.net) application is set to x86 (32 bit).
Should i install TestStand in its 64bit vesion?
Regards
Lior Meister
(17,744 Views)
Accepted by lior.meister
You could try that, but it seems like a long shot since your app didn't work as 32-bit.
Do the example C# user interfaces from your 32-bit install launch ok? If not, you should reinstall TestStand. If so, then there is something different about your app.
(17,739 Views)
hi,
i fixed both the solution and projects to be x86 and now it works fine!
thank you very much
Lior Meister
(17,705 Views)
even i am getting the same error in WINDOWS FORMS Application
tried so many alternatives
but still getting the same error
(9,612 Views)
What version of Teststand and Visual Studio did you use?
Usually, for Teststand2017, 2019, 2020, 2021, 2022, I suggest that you can try to use Visual Studio 2017 to open the demo and choose the correct architecture version (x86 or x64), which will ensure that you can open it correctly and compile without any errors.
(9,563 Views)
