Returning only final string of SubSequence
Hello
I have developed a Subsequence for my Main sequence, but struggle with the layout of the report. As you can see on the attached picture, I have concatenated the strings into one whole defined with "Bluetooth Address", but would now like to remove the steps "GetBTAddr 0,1,2,3" on the report.
I tried for the subsequence -> Disable result recording for All steps -> and then going into the subseq for the function concatenating the strings, under Run Options, to change the "Result Recording Option" to "Enabled (override sequence setting)"
I get errors on report then. Please help me out. Thanks in advance
(2,324 Views)
You could change your GetBTAddr, GetBTAddr1, GetBTAddr2, GetBTAddr3 steps from String Value Test steps to Action steps?
(2,300 Views)
Hi
I tried this, but it didn't help me much. My function wont print the Bluetooth address then, and I still want to exclude "GetBTAddr0" etc from the report.. See attached png to see result of changing to Action steps
BR Andedam
(2,294 Views)
Accepted by Andedam
See attached.  The BTAddr steps are now Action and Result Recording is disabled.  The concatenation of the BTADddr strings in the new String Value Test step uses RunState.Sequence.Main[GetBTAddr1].CSP.SequenceParameters.Result.StringValue which I think is where the BTAddr steps place the addr read.
(2,279 Views)
Thanks a lot! This sorted it out! Thanks!
(2,273 Views)
Happy days!
(2,269 Views)
