NI TestStand
Rich Edit Box in MFC Operator Interface
Hi
I'm trying to add a MFC Rich Edit box into my OI. However each time I add in the box, my OI cannot be loaded. FYI I can compile my OI code without any error.
I'm writting my codes based on the simple MFC OI from the NI OI sample. What I did is just add the rich edit box from the MFC control into the OI dialog box and my OI.exe cannot load the OI anymore.
I'm using TS3.5 and VC6
(3,432 Views)
Hi caviars,
I believe this is related to how you are using the Rich Edit box. See here and here.
Test Engineer - CTA
(3,416 Views)
That is the reason why it failed to load. Thanks for the info.
(3,409 Views)
