NI TestStand
String to Hex to Decimal For Comparison
I'm running TestStand 3.0 using Win2K on an 8186 controller.  I'm reading a string of hex characters.  We pass these characters into a string variable.  I want to take the string, convert to hex and convert this hex to decimal so that I can do a numeric comparison.  Example, a "2A" comes back as a string.  I want to find out if its less than 11 in decimal.  Will TestStand allow me to do comparisons in hex and if not, how do I make the comparison.  My assumption was that I have to convert everything into decimal to do the comparison.
Tony
(9,522 Views)
Tony,
Use the Val() expression in TestStand.  For example, Locals.X is a string, Locals.Y is a number.
Locals.X = "2A",
Locals.Y = Val("0x" + Locals.X)
At this point, Locals.Y is now 42.  You can choose to display this as 2A or 42, depending on your formatting options.  In any case, it represents the same number- the integer 42.
(9,509 Views)
This is exactly what I was looking for.  Thanks for the assistance.
Tony
(9,501 Views)
