Right Click Show step in context tab, where has it gone it the latest version of Teststand
I used to right click on a step and select "Show Step In Context Tab". I could then change values etc on the fly. In the latest version of Teststnd I can't find where I can do this. This was very handy for changing values etc during development.
Any help appreciated.
Nigel
(3,274 Views)
Are you using TestStand 4.X?
There should be  a Tab that you can select which gives you the view that you what.
regards
ray farmer
Regards
Ray Farmer
(3,262 Views)
Accepted by noog
There is a context menu "Show Step in Variables" that does exactly the same thing. It's called a Variables View rather than a Context View in TestStand 4.0 and higher.
Hope this helps,
-Doug
(3,253 Views)
Thanks for the replies; the show step in variables does it...
Thanks again this saves a fair amount of time during testing etc.
(3,238 Views)
