‎05-29-2006 04:21 AM
‎05-29-2006 02:00 PM
‎05-30-2006 03:51 AM
‎05-30-2006 05:54 AM - edited ‎05-30-2006 05:54 AM
You could modify your process model to dynamically call a sequence run it and then and dynamically load another sequence and so on.... until all of your sequences have been run. you would need to add control into the process model that decides which sequence gets run when, and also when to finish looping a terminate.
Take a look at 'Engine.GetSequenceFileEx' and 'Execution.ClientFile' methods if this sounds like the sort of thing you need.
Regards
Steve
Message Edited by SercoSteve on 05-30-2006 05:55 AM
