NI TestStand
How to add and run PreUUTLoop and PostUUTLoop together when I click ""Run selected steps" in the context menu of certain sequence in Main sequence
  My sequence file is made of several sequences, which contain hardware initialization in PreUUTLoop,hardware close in PostUUTLoop and test sequences in main sequence. See attached file.
  I'm looking for a way that everytime I choose "Run selected steps" in the context menu of certain sequence in Main sequence, it could automatically execute PreUUTLoop first, then execute selected sequence, then last the PostUUTLoop. Hope somebody could give me some suggestions on this.
Jacky
(3,260 Views)
There are two callback sequences you could use SequenceFilePreInteractive and SequenceFilePostInteractive.
You could put your Initialisation and cleanup.
Or you could just do the "Run Selected Steps using - Test UUT's" which would run that selected step(s) using the Entry Point Test UUT's which performs the PreUUTLoop and PostUUTLoop.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,255 Views)
