NI TestStand
TestStand Error Code -18004
In TestStand, I get this error, "Error, LabVIEW: VI was aborted. [Error Code: -18004, An error occured accessing the LabVIEW Run-Time Engine DLL.]
I am using the LabVIEW Run-Time engine as the TestStand adapter and running a modified version of the simple LabVIEW operator interface.
This is an intermittent error; it happens maybe 5% of the time.
I am using TestStand 3.5 and LabVIEW 8.0.1
What is causing this error?
(6,133 Views)
Hi ab0123,
First try mass compiling the directory that contains the VIs you are trying to run. If you are running our examples, mass compile the whole examples directory.
If this doesn't work, also mass compile the LabVIEW operator interface directory and then rebuilt the executable.
Let me know what happens!
Jonathan N.
(6,108 Views)
Jonathan,
Thanks for the reply.
I have already done the mass compile of all those directories and the OI has been rebuilt several times.
(6,092 Views)
Hi ab0123,
Do you see this error in the Sequence Editor as well?
You may also want to mass compile the whole TestStand directory as well as there are VIs that are also called.
Hope this helps!
Jonathan N.
(6,071 Views)
Have you tried it with the default simple OI which has been rebuilt using labVIEW 8.0.1, rather than your modified version?
Regards
Ray Farmer
Regards
Ray Farmer
(6,069 Views)
I have rebuilt the simple Labview OI using LV8 and also mass compiled a copy of the demo Computer Motherboard Test seq VI's.
I have set the labVIEW adapter to use the runtime engine.
I have run the sequence file in the OI quite a few times now using the Test UUT's, But I am not seeing your problems.
What environment are you operating your system in?
Regards
Ray Farmer
Regards
Ray Farmer
(6,064 Views)
Thanks for the replies, everyone.
I have not tried to run the sequence file in either the sequence editor or the unmodified simple OI for extended periods of time.  It may be difficult to get an opportunity to run under these environments since the sequence file is running a production test, and the test operators expect to see the familiar OI.
I would suspect the modified simple OI to be the problem since it does not shut down properly once the sequence file has been loaded.  It takes Ctlr-Alt-Del to shut it down.
(6,032 Views)
