NI TestStand
Running Labview-teststeps without having Labview installed
is it possible to create a Teststand-testplan with Labview-teststeps and to run it  _without_ having Labview installed?
Do i always need a Developer-Labview or is a Labview-Runutime enough to run the Tesplan?
Thx
(2,943 Views)
If you are using TestStand 3.x, then you can setup the LabVIEW adapter to use the LabVIEW RTE or a LabVIEW ActiveX Runtime Server. If you are using TestStand 2.0.x then you can only use the Runtime Server.
The User Manual, will help you to setup the LabVIEW adapter.
Off course you will still need the correct LabVIEW RTE version installed on your Target machine to match the version of your VI's..
Regards
Ray Farmer
Regards
Ray Farmer
(2,930 Views)
