NI TestStand
Set the description value for a step by using the TestStand API
to read the description of a step there is provided a method:
Step.GetDescriptionEx
What about setting this value via API?
I didn't found any method like 'SetDescriptionEx' !
Sunny
(3,777 Views)
The description is generated automatically by the Step Type and cannot be changed (you'll notice it is grayed out in the sequence editor).  You may want to use the comment field if you need to write arbitrary information about the step.
Allen P.
NI
(3,766 Views)
There is no set method because the description is dynamically computed by evaluating the DescriptionExpr property of the step's steptype.
If you want to make a custom step type with a settable description, add a step type subproperty of type string named MyDescription. Then set the step type's Step Description Expression to Step.MyDescription.
Now, for any instance of your step type, you can set the Step.MyDescription property to change the description.
(3,764 Views)
Hi James,
i will realise it as you suggested!
Sunny
(3,750 Views)
