NI TestStand
A fast way to write to the operator interface
Hi All.
I have a speed problem with writing to the OI, I have built a seq with around 900 measurements, and this seq takes about 33sec when called from the editor (with tracing disabled).
If I launch my OI (slightly changed NI simple OI), then the seq takes about 36sec.....
Then I enable tracing... and then it takes about 80sec..... hmmmm...
The last thing is that I have made a seq model post step (VI call), that makes a PostUIMessageEx to the OI with a text string describing what the last step has measured, this gives a time of 56sec......
So what to do...... maybe I can discard my post step vi and make it directly in the seq... maybe that will helps..........
are anybody have other ideas ????
I just need some simple information like..
Stepnumber, Step.Result.Numeric, step.Limits.low and step.limits.high.........  I just need a simple text indicator... just so the operator can see how it goes..
A shame that the tracer is so slow.... it is so pretty.. 🙂
Kind regards Thomas
(2,958 Views)
Instead of the PostStep and using the ActiveX, try putting the inforomation in a named queue and then draining that queue in the OI. Another thing that I use is to break the 900 measurments into sub-sequences and then trace only on the result of the sequence (don't trace into the sub-sequence). This provides a nice progress indicator if you can divide the 900 measurements into reasonably homogeneous chunks that make sense in a report.
(2,947 Views)
