NI TestStand
Terminate executions automatically before exiting
I want to disable the dialog that comes up when TestStand engine is going to be shut down while executions are still running ("You have incomplete executions...").
After this dialog you can choose "Terminate" for every execution. Is there any possibility to tell TestStand to terminate running executions generally without showing these annoying dialogs??
Steffen
(4,430 Views)
Wouldn't it be better to actually terminate the executions.
Attached is an example, where the execution reference is return from  a new execution and used in the cleanup to terminate that execution.
This is just one way.
Regards
Ray Farmer
Regards
Ray Farmer
(4,418 Views)
Hi
of course your suggestion is the appropriate way to do it.
But in my case this is not possible because I have two executions that are running until exiting the user interface (written in cvi) and with it shutting down the engine.
See this thread: http://forums.ni.com/ni/board/message?board.id=330&message.id=8023
(4,411 Views)
Is it the Operator Interface that starts these two execution?
Regards
Ray.
Regards
Ray Farmer
(4,409 Views)
no, these two execs are started in the sequence file load callback of the main sequence
(4,407 Views)
So, couldn't you use the SequenceFile Unload Callback to stop those excutions.
The Operator Interface will perform this task as it goes through the shut down process of closing any loaded sequence files etc..
Regards
Ray
Regards
Ray Farmer
(4,405 Views)
I've already tried this, but the problem is that the popup "You have incomplete executions [...]" comes up before the SequenceFileUnload callback of the main sequence is executed!
(4,400 Views)
