ā09-08-2005 05:43 AM
ā09-08-2005 04:50 PM
Wouldn't it be better to actually terminate the executions.
Attached is an example, where the execution reference is return from a new execution and used in the cleanup to terminate that execution.
This is just one way.
Regards
Ray Farmer
ā09-09-2005 02:29 AM
Hi
of course your suggestion is the appropriate way to do it.
But in my case this is not possible because I have two executions that are running until exiting the user interface (written in cvi) and with it shutting down the engine.
See this thread: http://forums.ni.com/ni/board/message?board.id=330&message.id=8023
ā09-09-2005 04:41 AM
Is it the Operator Interface that starts these two execution?
Regards
Ray.
ā09-09-2005 04:46 AM
ā09-09-2005 05:42 AM
ā09-09-2005 06:49 AM
I've already tried this, but the problem is that the popup "You have incomplete executions [...]" comes up before the SequenceFileUnload callback of the main sequence is executed!
