NI TestStand
Running a Seq File when executing UI (command line option) returns an error
I'm using a LabVIEW based UI to run/execute a sequence file using the command line option. My command line is D:\QF\GUI-Test.exe  -runEntryPoint "Test UUTs" D:\QF\GUI-test-Sequential.seq
When executed I get 3 popup's saying that some of the perameters "is not a valid LabVIEW file" (see attachments). Any idea how to avoid these messages? (The UI works fine and executes the Test UUT's entrypoint)
LabVIEW 8.5
TestStand 4.1
Thanks.
Message Edited by TomAndres on 02-09-2009 10:15 AM
Regards
Tom Andres Lomsdalen, CTD
(4,020 Views)
Try
D:\QF\GUI-Test.exe  /runEntryPoint "Test UUTs" "D:\QF\GUI-test-Sequential.seq"
Do you get the same errors if you use the default UI.
Regards
Ray Farmer
Regards
Ray Farmer
(4,011 Views)
Ray,
Using /runEntryPoint instead of -runEntryPoint  didn't help, but I tried both default UI's (simple/full) and it didn't return any errors. My UI is based on the simple, and I've made it even simplier. I'm going to stipt it for customer logos and son on an upload it. Thanks
Regards
(4,004 Views)
I've uploaded the sample code and exe file. I still get the error popups when running this UI. I've only added the execution list bar on this GUI compared to the TS default, and removed most of the ActiveX controllers.
Regards
(4,000 Views)
Accepted by TomLomsdalen
Hi Tom,
When you create a new application from you Build Specification, you have to set the "Pass all command-line arguments to application" in the Advanced tab.
Once you do this it should all work.
Regards
Ray Farmer
Regards
Ray Farmer
(3,962 Views)
Ray,
Excellent! That worked, thanks.
Regards
(3,958 Views)
