NI TestStand
Running sequence unmanned
OK, so here is the status:
I have a TempControl.seq file now which takes care of controlling the temperature by calling different VIs and also takes care of calling my Test.seq file, which has my actual testing sequence. As I need individual test reports for each and every run of my Test.seq file I call the it by using the "Use new Execution" option.
This works great, it really does what I wanted to achieve earlier.
The new problem though... It would make sense to define parameters to the Test.seq so the caller sequence could propagate info to it. But it seems that if I call the Test.seq with the "Use new Execution" option then I can not pass parameters to the called sequence.
Any idea how should I solve this problem?
thx!
Message 11 of 11
(285 Views)
