NI TestStand
SQL file to create 2016 default schema
Is there a provided SQL file to create the tables and columns for the TestStand 2016 default schema? I have not been able to find one.
I want to create an SQL file to add the columns to the tables with the changes from 2013.
Stephen
(3,450 Views)
Accepted by topic author stephenb2
I found "MySQL Create Insert Result Tables.sql" in:
C:\Program Files (x86)\National Instruments\TestStand 2016\Components\Models\TestStandModels\Database
(3,433 Views)
So it looks like the following should convert a MySQL database for TestStand 2013 to version 2016.
ALTER TABLE PROP_NUMERICLIMIT ADD THRESHOLD_TYPE VARCHAR(32);
ALTER TABLE PROP_NUMERICLIMIT ADD NOMINAL_VALUE DOUBLE;
ALTER TABLE PROP_NUMERICLIMIT ADD UPPER_THRESHOLD DOUBLE;
ALTER TABLE PROP_NUMERICLIMIT ADD LOWER_THRESHOLD DOUBLE;
(3,430 Views)
