NI TestStand
SQL query executes but returns no results
I am trying to query by a model number which I know exists in my SQL table.  When I run the query in SQL management studio and in the NI Database viewer the result is returned as expected but when I try and execute the same query via an open SQL statement in teststand no results are returned in the following Get Data Operation
(4,215 Views)
Hi St3venA,
Have you ensured that the query has the proper syntax? Please refer to the following forum for a similar issue:
https://forums.ni.com/t5/NI-TestStand/SQL-Query-in-TestStand/td-p/381657
Alex
Hardware Engineer
(4,189 Views)
