NI TestStand
Sequence Editor Crash
I get to see "SeqEdi 5.1.0.240 encountered a problem and need to close" error message for a Step quite often.
Below is the screenshot of the error message I keep getting.
Any help how I can fix this?
Thanks in advance.
Sagar Joshi
(3,020 Views)
Does anyone have a solution for this Post?
(2,959 Views)
You should open up a ticket with NI Support if you have a problem like this.
A few general troubleshooting steps i'll mention:
  • Try to narrow down what step is causing the crash
  • If you can narrow down what step it's crashing on, that's indicative of a bug in the code module called by the step (or the drivers used by the code module)
    • Does it call any C/C++ dlls? If so, whoever developed those dlls is probably the best suited to help troubleshoot
  • Check the known issues list for your versions of TestStand & LabVIEW (if applicable)
Another thing worth noting is that features were added to TestStand 2017 to help troubleshoot issues like this.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,932 Views)
