NI TestStand
Using Labview NXG VI in Teststand 2017
I am trying to run a LabVIEW NXG VI asynchronously from Teststand 2017. It is asking me to locate a .gll file which I couldn't find. Can anyone help me with this?
(2,450 Views)
When set to runtime engine, the LabVIEW NXG adapter can only execute code from .glls. You'll either need to change the adapter settings to use the development environment, or build the code into a GLL.
As long as your project has a .gcomp with the sub-type set to .gll, the adapter will automatically build the GLL for you when you execute the sequence.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,426 Views)
