STDF PRR Field
Hey Ed,
Yes, what you have there looks correct to me. I would expect the Part_TXT field in the PRR to be populated with that expression. Here's an example from my test program with a similar Statement step:
Message 11 of 18
(1,679 Views)
hi Daniel, which version are you using ? we are using 2016. I don't why it s not working .
Message 12 of 18
(1,648 Views)
I don't think TSM 2016 support writing to PRT_TXT of PRR.
Santhosh
Soliton Technologies
Message 13 of 18
(1,638 Views)
Hi Santosh, do you know which version supports writing to PART_TXT field ? thanks
Message 14 of 18
(1,632 Views)
if I am Using teststand 2016 which STDF version am I using ? Writing to PartTxt field is only for STDF version 4 right ?
Message 15 of 18
(1,627 Views)
It is not about the STDF version, it is about whether the TSM version exposed a way for the user to log data to other fields like PRR.
Santhosh
Message 16 of 18
(1,617 Views)
Hi Santhosh,
Thank you for your help.  If the STS package (LV, TS, TSM regardless of version) accepts the statement at runtime ... should it work?
Ed
Message 17 of 18
(1,606 Views)
I was testing with a newer version (TestStand and TSM 2021). After that note, I installed 2016 to try it there and saw similar behavior to you where the PART_TXT field wasn't being set.
After investigating further, it looks like we discovered that the functionality to set the PART_TXT from MainSequence stopped working in 2016, and we re-added that functionality in TSM 2019. That explains why it was working for me on a newer version. Our apologies for the incorrect documentation in the 2016 version.
So there are two options to set PART_TXT:
  • Upgrade to TestStand 2019 or newer, or
  • Set the PART_TXT field within the StartOfTest handler driver entry point (if you are using a handler, and if you have the data to set the field at that time).
Message 18 of 18
(1,600 Views)
