Saving persistent data in sequence file
I'm doing this in 'C', please translate!
Message 21 of 24
(1,275 Views)
SeqFileSave(fileHandle, NULL, "");
Message 22 of 24
(1,275 Views)
Ok, I put in that last call to save the sequence file if the new value is different than the old value instead of telling TestStand of the file change and everything appears to work great. Mission accomplished!
Guys, thanks for your patience with what must have seemed to you to have been trivial.
Message 23 of 24
(1,275 Views)
To Hurst -
Glad to help. Good luck with your programming...
Scott
Scott Richardson
https://testeract.com
Message 24 of 24
(1,275 Views)
