Selecting Multiple Lines for Copy/Paste on the Additional Results tab?
On the Additional Results tab, is there a way to select multiple custom results for copy/paste ?
George Zou
(5,685 Views)
No. Single Selection only.
(5,172 Views)
Accepted by zou
Problem solved.
I created a sequence to retrieve all CusomResults from the selected step in the source sequence, save to a shared fileGlobal; and then push to the selected step in the target sequence.
Add the sequence to TestStand Tools menu.
George Zou
(5,162 Views)
Were you intending to share the sequence file? Your post doesn't have an attachment.
(5,133 Views)
No.  I wasn't.  It's really simply.
But here it is.
Add it to the TestStand Tools menu.
To use, select the source step, run the Get sequence from the menu bar; then navigate the target step, run the Set sequence.
By the way, anyone knows how to enable undo?
George Zou
(5,129 Views)
