Selecting specific elements of a string
I'm working on a program that requires a certain sequence of outputting from a string. In python, I am able to use this line to select the last 2 elements of the string to be added to the first 2 elements of the string to form the output
sl=str(z1)
sll=sl[-2:]+sl[:2]
Any idea how to replicate this in teststand.
Locals.hextstr=Str(Locals.y1,"%x"), Locals.hextstr2=Str(Locals.y2,"%x"),Locals.s=Locals.hextstr+Locals.hextstr2
I need to get the last 2 elements from hexstr and then to be followed by the first 2 elements of hexstr and repeat this for hexstr2 also
(7,391 Views)
Accepted by tonye546
TestStand has two functions, Left() and Right(), that you can use to extract some characters from the beginning and end of a string.
Let's say you have Locals.String = "12abcdef34"
and that you display the following code in a message popup: Left(Locals.String,2) + Right(Locals.String,2)
you would get: 1234
Marc Dubois
(7,367 Views)
Use left() and right() string functions.
Have you looked at available functions for teststand expressions? The expression browser list all available functions.
(7,365 Views)
Thank you. That was very helpful
(7,330 Views)
