10-07-2025 08:34 AM
What is the goal for the TestStand Semiconductor Module, and Veristand Steps in TestStand. Right now the currently released versions require you to use TestStand 2023. I'm guessing this is a limitation of those things using .NET Framework, so TestStand 2024+ is out of the question.
I have multiple stations coming up, that will need to use Semiconductor or Veristand in TestStand. I would rather use TestStand 2025 if possible, is there a roadmap or timeline when Semiconductor and Veristand will support modern releases of TestStand.
10-07-2025 08:38 AM
Is there any feature in TS2025 that you would like to use? if not I don't see a reason not to use TS2023
10-07-2025 08:46 AM - edited 10-07-2025 08:49 AM
I'd rather use .NET instead of .NET Framework on the backend, especially since all versions of TestStand going forward will be .NET. That way I can future proof my applications, custom code, and make them easier to update to newer versions without recompiling everything.
Not to mention a lot of the report fixes in TestStand 2024+ are things my customers want (those specific things are outside of Semiconductor but in use with Veristand). Fixes like the on-the-fly reporting, pdf generation. And a big one we've had problems with is the deadlock issue with enums and LabVIEW that was fixed in 2025 Q2.
10-07-2025 08:48 PM
Out of curiosity, would you mind sharing what kind of application are you working on that uses both STS and VeriStand?
10-07-2025 09:21 PM
I think he has both applications separately but would like to be standardized on TS version within the org.
10-08-2025 03:51 PM
