NI TestStand
Send data from Edit SubStep to OI
Hi folks,
I've got some information I'd like to send from an Edit Substep to a LabVIEW user interface that provides (amongst other things) a custom sequence editor.
What's the preferred way? UIMessage ? Flattened data (to Str) via TCP ?
Cheers
Chris
Don't forget to give Kudo's for a good answer !
LabVIEW Champion
Certified LabVIEW Architect
Certified TestStand Architect
(1,175 Views)
UIMessage is the default first choice, but that doesn't mean that other alternatives can't be considered if they have an advantage for a situation.
(1,148 Views)
Hi Chris,
i agree, UI messages are best choise,
this thread gives more information (page2):
https://forums.ni.com/t5/NI-TestStand/Seq-context-in-multiple-executions/m-p/839744
Depending on what your are doing, keep in mind that your stuff, especially feedback's from your UI, tiggered by the UI message will not work with NI-SequenceEditor anymore.
So i often have used TS-Queues for sharing data over sequencefile,process and maschine boundaries.
https://forums.ni.com/t5/NI-TestStand/Sharing-a-string-by-a-queue-from-Execution-to-execution-on/td-...
https://forums.ni.com/t5/NI-TestStand/Best-way-to-pass-parameters-to-sequences-called-as-new-executi...
https://forums.ni.com/t5/NI-TestStand/Marshalling-the-IEngine-object/m-p/666852
Best regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(1,130 Views)
