NI TestStand
Sequence Context Ref
Are there any difference between these two references?
The monochromatic one comes from \vi.lib\addons\TestStand\_TSLegacy.llb\LabVIEW Test - Sequence Context.ctl. I see this in all of my older code (some from TestStand 1.0). This is defined as a strict typdef.
If you create an Invoke Node that is linked to the legacy monochrome control and then create a control from the reference input of the Invoke Node, you get a 'pink' refnum.
Message Edited by Phillip Brooks on 01-13-2010 04:15 PM
(4,239 Views)
Great question! I don't have an answer but I found another way to create the 'colored' reference. Chose a automation refnum and select TS.SequenceContext as the ActiveX class. I also wondered this when comparing the instructions from my TestStand 3.0 classwork with the latest LabVIEW user interfaces for 4.2.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,223 Views)
There is no difference.
Regards
Ray Farmer
Regards
Ray Farmer
(4,220 Views)
Accepted by topic author PhillipBrooks
The "pink" control is a standard Automation Refnum. The "black" control is a Type Def of the standard Automation Refnum. If a subVI uses the Type Def as an input and you wire a standard Automation Refnum to the input of the subVI you will see a coercion dot (and vice versa).
Hope this helps.
Manooch H.
(4,194 Views)
