01-13-2010 03:11 PM - edited 01-13-2010 03:15 PM
Are there any difference between these two references?
The monochromatic one comes from \vi.lib\addons\TestStand\_TSLegacy.llb\LabVIEW Test - Sequence Context.ctl. I see this in all of my older code (some from TestStand 1.0). This is defined as a strict typdef.
If you create an Invoke Node that is linked to the legacy monochrome control and then create a control from the reference input of the Invoke Node, you get a 'pink' refnum.
Solved! Go to Solution.
01-13-2010 11:34 PM
01-14-2010 12:58 AM
There is no difference.
Regards
Ray Farmer
01-14-2010 03:27 PM
The "pink" control is a standard Automation Refnum. The "black" control is a Type Def of the standard Automation Refnum. If a subVI uses the Type Def as an input and you wire a standard Automation Refnum to the input of the subVI you will see a coercion dot (and vice versa).
Hope this helps.
