NI TestStand
Sequence Editor won't start
I have an evaluation version of teststand 2014  32 bit (it was working ) but now  i can't open the SeqEdit.exe and i have this error in capture :Error : Win32 Handle that was passed to Icon is not valid or is the wrong type .
i try to unstall all NI software in my PC and install again but still have the same problem
Any help with this please
(2,864 Views)
Hello
I see that you have tried uninstalled and reinstalled the software but that didn't solve the issue.
Have you attempted a force reinstallation of the software? This could solve issues that a regular reinsallation wouldn't solve.
Force Reinstall Non-Working or Corrupt NI Software
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8U0SAK&l=en-US
Have you tried running the sequence editor as administrator? If the program does run with administrator privileges there are some steps we could try to fix the issue. I know this is not the exact issue you're having, but you can try these steps to see if they help you.
Cannot Open TestStand After Changing the TestStand Configuration Directory
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6rWSAS&l=en-US
(2,834 Views)
Hello ,
Thanks for your response , Yes i'm always runnig the sequence editor as an administrator .
So i try to force reinstall ni teststand (setup.exe) using the Command Prompt ,i finish it and reboot but still the same error .
any explanation of the error ? other suggestions ?
PS : OS :Windows 7
        TestStand 2014 32 bit
Best regards
Ahmed
(2,830 Views)
