NI TestStand
Teststand failure results are kept for the nexst UUT
Dear Friends,
Could you tell me how to solve the following problem?
If the first UUT testing failed in some steps of the main sequence, the failure results will keep in the next UUT test report file if we continue to test next UUT by click the NEXT.
However, if we close the TestStand then re-start the same application sequence file to test, we can get the new test results for those failed previously.
It seems the failure results are resided in the memory and will keep in the test report for the next UUT and another next UUT if just click NEXT.
Is there any configuration setup to correct this problem?
Thanks a lot,
James
Message 1 of 1
(2,037 Views)
