Sequence File Documentation
Hi, is there a means of modifying the report generated when using the TS built-in "Sequence File Documentation" feature. I know for execution report generation, there is a sequence file itself that can be mod'd, but can the documentor be tweaked?
rjmiller
(3,946 Views)
Yes, the TestStand documentation generation tool is located in \Components\NI\Tools\DocGen. Within this folder there's a set of sequence files that you can customize: one main sequence file (docgen.seq), and two format-specific sequences (docgen_html.seq and docgen_txt.seq). Also, the LabWindows/CVI source code is provided that displays the dialog box is provided as well.
David Mc.
(3,944 Views)
Has anyone modified the DocGen.seq to include the Comment field in TS Sequence Editor?
It seems odd not to include this in sequence documentation. This trying to save some time here.....
Was comment field only added for the NI Requirements Gateway?
-Chroma
(3,793 Views)
Chorma,
The Comment field is included in the sequence documentation. You have to have enabled the Show Subproperties.
Regards
Ray Farmer
Regards
Ray Farmer
(3,767 Views)
Can't see the woods for the trees.... thanks for that!
-Chroma
(3,739 Views)
