NI TestStand
SequenceFileUnload callback starts parallel thread
Hello All,
I would like to create a SequenceFileUnload callback to my client sequence files, which would start a parallel thread starting a sequence of another sequence file.
This new Thread would perform some actions (access) on the client sequence file itself , but always returns with an error, because the client sequence file is not closed until the parallel thread is running.
I already unchecked the "Automatically Wait for the Thread to Complete..." setting
Thank you in advance for you help and time.
CsBihacker
(2,697 Views)
Accepted by CsBihacker
I would do it in a new execution.  Executions cannot complete until all threads are completed.  So you can't operate on the file because it won't be done until the thread it spawned completes.  Executions, however, are different.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,668 Views)
Thank you for the hint.
Does this mean that an execution entry point is used when running SequenceFileUnload callback?
Which one?
CsBihacker
(2,643 Views)
I managed to create a new execution, and started this without process model, so this is running after the client sequence file is closed.
CsBihacker
(2,625 Views)
Glad you got it working!!
jigg
CTA, CLA
testeract.com
(2,619 Views)
