Set LabVIEW adapter to auto detect programmatically
Hi
I can programmatically set the LabVIEW adapter inTestStand to 2011 RTE using this expression:
RunState.Engine.GetAdapterByKeyName("G Flexible VI Adapter").AsLabVIEWAdapter.SetServerInfo(LabVIEWServer_RTEServer,"C:\\Program Files (x86)\\National Instruments\\Shared\\LabVIEW Run-Time\\2011\\lvrt.dll")
I would like to set the adapter to "Auto Detect VI version" instead. Do anybody know a solution to this
BR
Mogens
(4,397 Views)
Accepted by m-nielsen
Try this:
RunState.Engine.GetAdapterByKeyName("G Flexible VI Adapter").AsLabVIEWAdapter.SetServerInfo(LabVIEWServer_RTEServer,"AutoDetect")
I used the GetServerInfo method with mine set to autodetect and that's what it returned.
Hope that helps,
jigg
CTA, CLA
testeract.com
(4,384 Views)
Thank you jiggawax
That was just what i was looking for
BR
Mogens
(4,378 Views)
Thanks jiggawx, I was also looking for this.
this expression will return the LabVIEW adapter to Development environment:
RunState.Engine.GetAdapterByKeyName("G Flexible VI Adapter").AsLabVIEWAdapter.SetServerInfo(LabVIEWServer_ExecServer,"LabVIEW")
I am still looking for a programmatic way to set tjhe LabVIEW Version. Right now am relying on procedural (last version of LV launched).
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
(3,211 Views)
