Set Test Socket during Interactive Mode
I'd like to execute a single step using Interactive Mode on a particular Test Socket that I specifiy. In order to do this I suspect that I would set RunState.TestSockets.MyIndex prior to step execution (may preinteractive callback). How can I implement this without adding preinteractive callbacks to all subsequences? Adding a preinteractive callback to process model does nothing since the process model is not used when performing interactive on a subsequence.
Any ideas?
(3,695 Views)
Accepted by derek@clustr.dev
In your StationCallbacks.seq file add the StationPreInteractive callback.
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,679 Views)
