NI TestStand
Set a Default CVI Function parameter
I am wondering if there is a way to set some parameters of  a function as default. For example I am working on a project that will be using TestStand API so everytime I call a function in TestStand I will have to be filling the parameter with "ThisContext" so that I can use TestStand API functions in CVI. I would like to create functions that could auto fill this parameter with the a variable that I know that exist in teststand execution.
Thanks for your comments.
(2,519 Views)
What about creating a copy of the step type and creating some code templates? You could also just make some step templates that you can drag in and modify.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,492 Views)
If you are using the TestStand API you can use the pre-expressions of the step to run:
Step.TS.SData.Call.Parms[1].AsCommonCParameter.ValueExpr= Variable1
Where Parms[1] is the parameter index in the function prototype and Variable1 is a string.
(2,473 Views)
