NI TestStand
Write/Read Text File In TestStand 14
I have an application which I flash a circuit board. There are offsets which must be stored into 12 locals variables (locals.var1, locals.var2...) (1) I want to pass those offsets into a text file so that at some point we can (2) reload them into the board after repair. Each board has a unique serial number which I want to use as a filename. I thought about using the PropertyLoader to read the text file but each file would have a unique name. Can someone show me how I can create a solution to my problem?
(4,236 Views)
If the issue is a unique file name, you can use an expression to specify the file name.  In my own case, I might use different property loader files in the same sequence, but there are different values for different countries or different "flavors" of product.  Below is a picture.  (Note that this example uses the "Legacy" property loader.)  Here, "MyFilePath" is determined by the model number and/or serial number that the user enters in PreUUT.
Pulido Technologies LLC
(4,215 Views)
This would take care of the unique file names. Unfortunately, I get an error box complaining about the limits file. TestStand is looking for a limits file with the new filename. I tried initially placing the PropertyLoader in MainSequence, then in Cleanup and then in its own sub-sequence. All with the same result, looking for new limits file names.
(4,205 Views)
Perhaps I don't understand the issue.  By the time the property loader step is called, does the file not exist yet?  This method won't work if the file doesn't exist.
(4,200 Views)
Attached is a simple file I created to run the PropertyLoader after the data is collected. Hopefully you will see the same error.
(4,198 Views)
So you would need to create this file before calling the property loader step, so I wouldn't expect the property loader step to work.
(4,196 Views)
