NI TestStand
Set/save value of locals from LabView at development
Is it possible to set/save value of locals in Teststand from LabView at the development, so i dont have to write the value in the variables pane? I can do this at programmatically at runtime with SetProperty, but i want to set them in the development with a VI.
I use LabViwe 2012 SP1 32bit and Teststand 2012 SP1
(5,462 Views)
You do the same thing as you would in an application.  Just run the VI in the sequence you want the locals to be written to.  You could tell all of the other steps to skip when you do this.
(5,447 Views)
Rokot,
Do you want the values to be stored to disk?  Or do you just want to change them during run time?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,440 Views)
In runtime it works, but i want to set the value before when i develop the testsequence.
For example: There is a testseqauence with a Local.localnumber I want to set with a vi and change the values to 10.TeststandLocal.png
If I run the sequence, the value changes to 10 but after the sequnce is over it changes to the default value of 2. Is it possible to change the value durable?
(5,431 Views)
Accepted by topic author Rokot
You have to acess the SequenceFile Locals and then save it to  disk.  I've attached an image as well as my code.
jigg
CTA, CLA
testeract.com
(5,408 Views)
Good idea, it should fit.
(5,392 Views)
