Setting Sequence Properties
Hi TestStand community,
In the sequence properties, you can set the execution flow of the sequence on step failure (No Action, Goto Cleanup, Use Station Option). But this is a manual setting for the sequence. Is it possible to programmatically change this setting for a given sequence?
What we are trying to do is run a sequence in one of two modes. Either:
- Production: Immediately go to cleanup on sequence failure
- R&D: Continue executing subsequent test steps if a test step fails
(2,424 Views)
(2,353 Views)
I guess what you are looking for is Immediately Goto Cleanup On Sequence Failure option.
You can find it under Configure-> Station Options->Execution
Station Options Dialog Box - TestStand 2019 Help - National Instruments (ni.com)
Roman
(2,303 Views)
Accepted by Nightshade42
(1,806 Views)
