NI TestStand
Show subsequence steps in real time after it executed
Hi all,
My sequence(main seq) has a "large" subsequence, i mean, subsequence has a lot of steps. I want to see each step result of my subsequence after it has executed because in case it fails i want to see in which step is. How can i do that?
Thanks all,
(see attachment to clarify my description)
PD: My idea is double click in subsequence call and view the results
Message 1 of 13
(3,409 Views)
Would on the fly reporting work for you?
In my own situation, I have a VI that displays step data/results and I have a sequencefilepoststep in my sequence that enqueues these results.  This probably adds more complexity than what you're thinking.
Message 2 of 13
(3,373 Views)
Thaks for the answer!
I think that solution is a complex solution.
If my subsequence was in main sequence, i could see the last steps results. However, is not posible see the results located in a subsequence?
I think that test stand contemplates this action because i need to see why subsecuence was fault, f.e, in my picture (previously attached)
Message 3 of 13
(3,359 Views)
Your Report Should show the results of Individual Steps of the Sub Sequence, Check whether Result Recording is disabled?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 4 of 13
(3,349 Views)
Thanks for the answer,
It is true I see the step results of subsequence in the report. However I want/need to see after execution because is possible to do actions, such as repeat specific steps for example.
Message 5 of 13
(3,347 Views)
I am not able to understand your Question, Since After Execution its Report which you need to Consider, why you need Sequence Steps?
Message 6 of 13
(3,344 Views)
Imagine next situation i have a main sequence with five subsequences and i set breakpoint for example in subsequence 2. Main execution is not finished but subsequence exectuion of subsequence 1 is already finished. I want to see why subsequence 1 failed (see attachment)
My apologies if my explanation is hard to understand.
Message 7 of 13
(3,339 Views)
Enable Tracing for Sub Sequences you can see whats happening during RUNTIME?
Yours Status can be Seen in Report itself.
Message 8 of 13
(3,336 Views)
Yes, I can see step by step the criteria of subsequence steps in run time (when this subsequence is running). But when subsequence is finished i cannot see the results.
In my previous picture, subsequence execution is already finished, and I want to open it and see all steps with their criterias.
Message 9 of 13
(3,334 Views)
Enable On the Fly Reporting.
Message 10 of 13
(3,331 Views)
