NI TestStand
Show subsequence steps in real time after it executed
I set this function and I have the same problem. I share my configuration if i did a mistake 
Message 11 of 13
(575 Views)
You could also try using "Break on step failure". This way you can decide whether to go on with the execution or repeat the step.
Obviously, this is only practical for debugging - for operator use I would suggest to implement a "first-pass-exit"-loop over (few!) crucial steps to minimize operator interaction.
Best regards
J. Ludwig
Message 12 of 13
(563 Views)
Yes it's a good idea, I already had thought in that but I can't believe that test stand does not contemplate my situation. I think is a typical situation
Message 13 of 13
(557 Views)
