Showing the Status of the UUT on Custom User Interface (Labview)
sorry if there's already a discuscussion about this, but i can't find anything that brings me further.
I've got a Picture Ring Control on my front panel which includes pictures for PASS, FAIL, RUNNING and NO RESULT. If the Test changes its state, the Ring control should be updated. So i think i have to work with Event Callbacks, and also tried a little bit, but with no success. Where do i get the state of the Execution ? If the execution is over, do i seperately have to find out if it's PASS or FAIL or is there a variable or something where i can find it alltogether ?
I hope my question is clear. Many thanks in Advance,
Stevie
(3,164 Views)
Share the snippet/VI you tried, based on that we can provide suggestion.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,146 Views)
Accepted by StevieP
Hi !
You'll have to deal with UIMessages
Check in the PostUUt callback of your process model : you should be able to get your UUT status and send it to LV using a UIMessage.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,132 Views)
Thank you very much, that was exactly what i was searching for!
Stevie
(3,097 Views)
