NI TestStand
Shutdown Teststand 3.1 Engine Hangs
I am using TestStand 3.1 engine in combination with Labview 7.1. Everything works fine until I run a sequence file. After this run the logout/login and the shutdown do not work anymore. The complete engine hangs. When I look at the description of the shutdown method it says;
<QUOTE> Closes opened sequence files and executions. This method also releases the TestStand Engine. <UNQUOTE>
So this method should close all files and executions! Can anyone help me?
Message Edited by rschalken on 01-25-2006 02:30 AM
(3,893 Views)
Is this in relation to an Operator Interface developered by your self? If it is does the default setup run ok?
Does the sequence file run and then logout/login and shutdown fails, or the sequence file doesn't run?
Dont really understand your quote and what is it a quote from.
Regards
Ray Farmer
Regards
Ray Farmer
(3,886 Views)
It is a operator interface developped by myself with the start of the NI examples! When using the operator interfaces of NI I got the same problems! The sequence run works fine! Everything works fine only the login/logout and exit does not work (this because they both use the shutdown method). The quote is from teststand help file! I added this quote because I found a article at the NI site; "shutting down the Engine". This article says that I have to close executions and sequence files, but Teststand help file says that the shutdown method does this automatically! That is why I added.
(3,882 Views)
Thats for the clarifications.
Are you using all the default process models, engine callback, frontend (login/logout sequence) sequencefiles?
Do you get the same problems if you use the SeqEditor.
Which language are you using, LabVIEW/CVI/C++.......and version.
Regards
Ray Farmer
Regards
Ray Farmer
(3,878 Views)
I use Labview 7.1 and I use an adapted process model. But I only changed some result handling. The Sequence editor works fine. As I said that the examples user interfaces of NI has the same problems! These also hang after running a sequence!
(3,876 Views)
Have you tried switching back to the default process model and ensuring the everything is still working.
Regards
Ray Farmer
Message Edited by Ray Farmer on 01-25-2006 10:18 AM
Regards
Ray Farmer
(3,876 Views)
