NI TestStand
Skip Sqeuence Execution on Step Failure!!
Hello
I am in a situation where i am calling sub sequences from another sequence & i need to skip the sequence execution on any step failure in a that sequence, so that i can run the complete test efficiently and with less time. Could you please let us know a probable solution for this.
Regards
(2,876 Views)
There is a setting Immediately Go to Cleanup on Sequence Failure that you can set on a sequence using the Sequence Properties dialog box, or for the entire station as a global setting using the Station Options Dialog Box. I believe this setting will do what you are asking for.
Hope this helps,
-Doug
(2,864 Views)
